Maybe I'm not using the right names for the boards. Here's what they're called in the manual from top to bottom:
-Video Processor(this is the one I swapped from Qix)
-ROM/I.O.
-Data/Sound (I mistakenly said I swapped this one)
So far, no progress, except for knowing that Qix's Video Processor does not work in Zoo Keeper. It works perfectly in Qix, though.
The video board is the same. I don't think it would hurt to swap them, meaning see if the zk video will work in the Qix this will test all of the 4116 rams at once.
the main ( big) rom board can be tested in the Qix. The only catch is you have to swap the roms.
Those are the correct names. It's not safe saying top or middle or bottom board as some cabs have them mounted different. also their should be 3 chips on the data/sound board that you could swap with the Qix board. I don't want to get to far ahead and cause confusion.
It may be a good thing if there was no change using the Qix video board. It could be telling us the problem is else where.
also check the data/sound board to see if it has been converted.
allen
