Help needed with Stunt Cycle
wvhyperboy
Clarksburg, West Virginia
Ok, I have an Atari Stunt Cycle that has a problem with ?? As you can see in the picture I get the Image on screen and it plays but I cannot get the screen to straighten up. It was this way before installing cap kit and did not change after install. I really need to get this going before Christmas as it is a gift for my son so any help would be greatly appreciated. I cleaned and checked the edge connectors, made sure IC's were seated and did a visual for bad/broken solder.
Hyperboy
horizontal tearing....try adjusting the horizontal coil(s). Which monitor do you have?
What I did was a complete cap kit, even that little pain in the ass one under the board and then per "cwilkson" suggestion I got a service manual and adjusted the Horizontal Width Coil to what looked best and finally went through the adjustment procedure from the service manual and bam! That beautiful little cycle was rolling across the screen in all it's glory!! The main thing I can say is follow the adjustment procedure and ask for help if you need it!
