All,
Sort of last resort here. Should have though of this earlier.
I sent Peter at APAR my only working 19K7635 Med Resolution Flyback which is now in China at the mfg. Problem is I didn't think to take measurements from the working unit before I sent it out as I stupidly thought the manuals would provide that. I'm testing these units now and I don't have anything but anecdotal evidence of actual voltage values for the various outputs of the flyback.
Ideally someone would be nice enough to send me their flyback or chassis from a 19K7635 (Toobin comes to mind) so I can get readings and return it. Hell, I'll even rebuild it for free but I need an OEM flyback.
See this thread to ID an OEM flyback that I'm looking for or post here and I'll let you know:
Let's document the K7000 series medium resolution monitors
Adding to the documentation - there are two types of yoke that I've seen used on the 19K7000 medium resolution monitors. One is the version that's pictured above, where the rings are integrated into the yoke assembly. The label information reads (it's pictured above, but I'm adding text so...
forums.arcade-museum.com
