Help my mvs pcb is not booting
omega13
Illinois
I recently was playing my mvs arcade and I decided to change the games. As I finished changing the carts I flipped the switch to power the arcade and only the monitor came on. I had trouble getting the cart in so I freaked out and thought that I broke the pcb. I purchased another pcb and installed it and still nothing. So now I am wondering is it possible that the switch is bad? If the switch is bad would the monitor still power on? Anyone who has any insight what to check, I would appreciate it. Thanks
Check the outputs of your power supply with a volt meter.
RJ
thanks. anyone else have any ideas?
You WILL find that your power supply isn't providing the right voltages. Whether it's because it died, or you have a wiring issue somewhere, you'll need to figure out yourself.
