Help! Monitor trouble in a virtua fighter 2 - extra wire??
ShacklersRevenge
Massachusetts
I swapped in a 25'' monitor in to my virtua fighter 2 because the other monitor crapped the bed.
It's a philips monitor, hooked red to red, blue to blue, green to green, then there was the two wire clip from the VF2 pcb (black and a blue with white stripe) the other wires coming off the monitor were white, a black and a yellow? Between different combinations, I've gotten the picture on the screen by hooking black to white, blue to white and the yellow??? but it's showing double images and a little blurry. Any help is appreciated as to where the extra wire goes! :/
Thanks, James
I am pretty sure VF2 is a medium resolution game. What monitor did you swap in? The double picture sounds like you have a standard res monitor hooked up...
