Ghostnuke
Well, the H oscillator must be running or you wouldn't get any scanlines-
Do you have a scope?
Are you sure the sync signals are getting to the IC501?
Scope out pin 16 there.
Does the HFreq pot do ANYTHING?
Your comment about the starfield is pretty confusing. Do you see a starfield in that picture you posted? I can't see a starfield.
Does anything happen if you hook the sync pins up to the other inputs? (positive vs negative).
No scope
If the HFreq pot is the one I'm thinking of, it doesn't change the screen much if at all but if I turn it, it causes a horrible high pitched whine the more I turn it.
It's hard to see in the pic, but I'm testing with a Galaga board. The indidvidual stars show up ok, but the ships and words and crap are the colored garbage.
