Black Matrix
Hey all,
I'm looking at this Electrohome G05-802 and I'm not sure what has been done or what I should do next. I believe this is an Issue 4 monitor. Plug 500 has the key in Pin 5 instead of pin 4 that is the normal V2000.
This monitor has a V2000 Deflection board(I think). Whoever put it there first bent down pin 5 of the P500 so the plug would fit down on it and I can only assume reverse it later.
So before I start capping and rebuilding this monitor, I guess my question is would this have worked when the person first did it. Is there a mod that will make the V2000 plug in compatible.
While the Black and White vector cap gives instructions to mode an Issue 4 deflection board, to an issue 5, I don't think it applies since I have a V2000 defection board.
Any insight or advice would be greatly appreciated.
