Has anyone installed a shaker into their LotR SE? I seem to be missing one connector.
The motor is installed, and plugged into the 5-pin connector in the control board. The harness that came with the motor connects to the 7-pin connector on the board. So far, so good. There are two large connectors going into the harness--2 and 3 pins--and it appears that each actually has just one pin used. OK.
There is one wired connector that fits the 2-pin, and it's in the bundle running under the flipper button. BUT: I can't find a 3-pin connector that should have a wire coming from the back of the machine. There is a smaller-sized 3-pin connector in that wire bundle, with 2 pins used by 2 separate wires, but the connector isn't the same at all. It looks like the missing wire/connector should be a brown wire coming from the rear of the pin (according to the shaker instructions for wiring if it's not pre-wired).
I closed up the machine for the night, but I can post back tomorrow with all wire colors if that helps. Right now I have found just one of the two wires/connectors that plug into the harness which then plugs into the 7-pin connector in the right of the controller board.
Any ideas on where to look for the missing shaker wire? Thx!
