help id'ing parts in a WG7905
Cartouche
Southington, Connecticut
I got this Arch Rivals from an operator out on Cape Cod. The monitor frame and parts of the chassis look like it was sitting for years on the deck of Sam's Clam Shack it's so rusted.
The game plays blind, no neck glow, fuse is good. I'm going to re-cap, replace flyback, and replace the HOT. The HOT solder joints look especially lousy.
Also, these two resistors at R90 and R93 look awful as well as this part in the second photo. Can anyone with a manual or smartz tell me these resistor values and what this transistor lookin' part is?
Thanks, Marc
Marc,
R90 is 1.2ohm 2watt
R93 is 1K ohm 2 watt
If you are talking about IC3 in the 2nd pic, it is a upc1378 for vertical deflection.
There were 4 different vertical output IC's used during the production run. Replace with the EXACT number of the one presently installed.
