Help identifying these joysticks?
MadPerry
Rochester, New York
I purchased an original Rough Ranger cabinet that came with 2 leaf switch joysticks. I like them but I want to get a red handle replacement to take place of the green. The first pic is what I currently have. The second is a pic of a lot someone is selling, that happens to include a red handle that is a bit beat up. I can't find any markings on these indicating who makes them, or where I could even buy them.
http://www.frontiernet.net/~madperry/Pictures/Raiden joystick.jpg
http://www.frontiernet.net/~madperry/Pictures/joystickpartslot[1].jpg
Hey There,
I may have what you are looking for. I got a bulk lot of used joysticks awhile back. Here's a picture of them:
You can click that pic to see a larger version. I can sell you the best red one for $15 + shipping. If you only want the stick and not the rest of the assembly, figure $5 + shipping.
If you want to take your green one out, and take the stick out of it and measure it I can tell you if the ones I have are the same exact size.
Pretty sure those are the ones! They measure approx. 5 5/8" long from shaft bottom to ball top, and the metal shaft is 5/16". The metal shaft is the same as a Happ ultimate stick, and the ultimate stick actually works in that joystick. they share similarities to the happ super, in that if you opt for a microswitch, you use the type with metal actuators and can flip over the white dealie on the bottom for 4 way operation. there probably is 4 small rectangular slots on the bottom of the base where you put plastic tabs for leaf switch operation.
I'm sending you a PM!
