Help identifying daughter board on Asteroids
Erich
Houston, Texas
Any one seen one of these before? Takes the place of a 74161 @ location 5C. It also has a chip clip that connects 2 leads to another chip, but it was loose so I don't know which one.
Thanks for the info! Can you tell me where the 2 loose wires (mine were orange and yellow) go? They were clipped to an IC elsewhere on the board but were pulled loose when I got the board.
Your kit isn't the same as the couple I've got.. Yours actually looks more legit, as mine have lots of wires soldered all over the place..
Move one wire around at a time, look where they reach to and check the legs of local chips or spots on the pcb. You should see solder on a leg somewhere. Sorry I can't be more helpful.
