Help Identifying And Adjusting Monitor
CMGTGuy
Mooresville, North Carolina
I was given this monitor by a friend and I have no idea what it is. I was able to drop it into my Pole Position and get an image on the screen, but can't figure out where the vertical or horizontal holds are at. Any help is greatly appreicated.
it is a 4600.
read the manual for it that is the best place to start.
like stated all the adjustments you need are on the two vertical cards.
Peace
Buffett
Yeah, horizontal hold. If that doesnt cut it theres a little metal can about a 1/4" tall on the X/Y board (not the one with the video signal cable) that might need a little nudge. USE A PLASTIC SCREWDRIVER.... If you use a metal driver you will change the value of the component thanks to the iron in the screwdriver. Your adjustment may not work after you remove the driver. That and you can easily break the core.
