daem0n
Hi guys,
Been a lurker for a bit and am now working on a cocktail system where I'm having some issues figuring out what I've got.
I have a Phillips tube and a Wells Gardner chassis. I can't tell much about the WG chassis though. I think it's a 7100 or 7200? Maybe you guys can steer me in the right direction. It looks to have the power supply built into the board so I'm thinking I don't need an isolation transformer?
Also, my main reasons for figuring out what the chassis is, is because I don't understand/know what the connections are to the chassis. It looks to be a 9-pin connection for RGB, Sync, etc and a 3-prong power connection. Is that all that's usually needed on this board?
I'm not totally clear on the 9-pin connections for the board either. Do they all have to be used? My Jamma cable only has 5 pins from my recollection.
Here are some pics in the meantime. Thanks for any and all help!
Image Descriptions:
-Full chassis board
-Image diagram of chassis that was pasted to the monitor supports
-One end of a cable (power cable?) that comes off of the chassis board
-A loose cable that I found inside the arcade cabinet - no idea what it's for?
-Chassis and serial number sticker
Image Descriptions:
-Full chassis board
