Help ID which chassis I need or.....
solo742
Colorado
In the quest for tube swap candidates, I have found the following that I have kept hoping I could find a use for them.:
Symphonic 19" with Funai tube (small neck, 8 pins (7 outside, 1 inside the trapezoid)
RCA XL-100 19" with RCA tube (large neck, 9 pins (8 outside, 1 inside)
RCA XL-100 19" with Samsung tube (Large neck, 10 pins, 9 out, 1 in)
I started my quest to replace a burned WG K4900 ad I am hoping the Samsung tube will work.
As for the others, I think I might just invest in a new chassis if I can and be done with it.
Basically I have two 4900's with burn, so I need to find donors for them. If I can use the others as well, (or someone else can) let me know.
Thanks.
