Help ID this monitor
Shavenyak
Donor 2023
Sarasota, Florida
This is in my Marble Madness. I think it's a WG7000 but it doesn't have the pots that Bob Roberts pics have. The last couple of pics show what the monitor is doing. Do you think a cap kit will fix it? Of course, I have to ID the monitor first. :)
That does look like a K7000.....I'd need better pictures (chassis removed) to be sure. It's possibly a late era K7000.
And the screen shots look like a motherboard problem.
Edward
That is a K7000. The missing pots are actually on a remote board, something many K7000 monitors have in order to make it easier to fine tune the pic.
That is indeed a late run K7000 with a remote adjust board. It looks like the flyback has been replaced already, too.
Well I'm looking at Bob Roberts' site for a cap kit and found this. I'm not sure which kit to go with. Any suggestions?
K7000 Series Cap Kits
What happened to the K7000 series standard cap kit? Well... someone noticed all those unused numbers in between & decided to use them, so it's no longer a K7000 cap kit, i.e., K7xxx to cover them all. Basically, the first 2 numbers now dictate the cap kit to use. I'll put a quick reference chart here to guide you to the correct kit.
Chassis Model Use This Kit
K70xx K7000
K71xx K7000
K72xx K7200
K73xx K7300
K74xx K7400
K75xx K7500
K76xx K7000
K78xx K7000
K79xx K7000
All Bob is trying to show there is that the 7200, 7300, 7400, and 7500 are totally different beasts from the regular K7000. (i.e. different cap kits)
You'll notice other kits listed for those others.
Yours is a regular K7000 version.
K7000 13"/19"/25" color $6.00
Thanks so much!
Well I did a cap kit and it fixed the problem. Figured I'd update the resolution for the records, in case anyone has the same issue.
