Help ID. Boards
charger
lincoln city, Oregon
OK i have approx 60 boards or so that i need help on. I need the room. I picked these up about 1 year ago and did the search on line and found out what a lot of them are(started with a little over a hundred of them) and sold some and kept some. And if you see anything that you might want let me know, and if i do not need it it's yours. Keep in mind these are just for parts. The first pic is just a group shot of the 6. The 2nd pic(1 board) says Amplifone Deflection A201014. The 3rd pic(3 boards) has A082-90412-C000 . The last pic(2 boards) has nothing at all on them. Thanks a head of time for you help. More to come later.
First pic top left are 90412 midway power supplys. Looks like they have acid damage so they probably dont have much value. Same pic on the right is an Atari AR power supply? Not sure what these were used in. I recognized it because I have one on my shelf. Mark, is this what your saying is a deflection board? Maybe I should take a better look at the one I have....maybe someone could use it.
First pic top left are 90412 midway power supplys. Looks like they have acid damage so they probably dont have much value. Same pic on the left is an Atari AR power supply? Not sure what these were used in. I recognized it because I have one on my shelf. Mark, is this what your saying is a deflection board? Maybe I should take a better look at the one I have....maybe someone could use it.
No, it's not an AR board.
It's an amplifone raster power supply + deflection board.
There's no need to follow up on my posts with wrong information.
