jeff412
I got a new Defender that had a broken connector on the Video board, so I pulled the one out of my working Defender to test. In the process evidently I bumped the working board against something and bent some of the transistors at the bottom of the board. This caused some of the legs to touch. When I plugged it in nothing happened. I thought I had something wrong with the new cabinet. When I put it back in the working cabinet. It no longer worked. I then checked the board and found the bent transistors. After getting them separated it still doesn't work. I get the initial Williams sound when I turn it on, but no video. What could I have burnt up with those transistors shorted?
Jeff
Jeff
