Help I need to get a game moved
Tamerlain
Ohio
Hello
New to the group and starting to buy the games I grew up playing. My question is I might be able to buy a game about an hour from me and the only way for me to move it is in the back of a SUV. The game would be on its back for the ride of about 1 to 1.5 hours. How bad is this for the game? Should I do it.
Thanks for your help
Generally this is fine. Ensure that the back is on securely and that all parts inside are also securely in place first. I've moved a lot of games this way with no trouble.
Make sure the MONITOR is secured tightly! If you're worried at all about how close it is to the back door, move the game on it's side.
Take out the coin box and anything else that may be loose inside the game.
Make sure you can turn it on and off at the pickup location (if it works) and verify all the functions BEFORE you move it, so that if you have a problem when you get it home, you know it's most likely something that came loose during the move....
definitely check the inside. I layed a Primal Rage into my SUV, heard a loud CLUNK, opened it up at home, and there was a set of vice grips in there. nothing was smashed, but coulda been bad..
