one is model # ms8-25B this is not the chassis with r-433 &c-433. it is completly different. I started with it shuting down after some caps & turning the B+ down way low it stays on, but now I have vertical collapse evan after changing vertical caps & IC401 LA7833. any Ideas? also what is the proper B+ voltage? I also have 2 27" chassis shutting down right after power up, Ihave done acap set in the B+ area & checked Q901,D502,& Q533they seem to read good. this chassis dosent have a model # on either one ,but stamped on the C/B is the #05A00585D1. any Ideas? also need to know what the B+ should be ? any info would be great and would love to find some schematics. thanks sherry
