help! game works when it feels like it but not with a different board?
ShacklersRevenge
Massachusetts
Here's the story- put a 60-1 in a regular cabinet and it works when it feels like it? most of the time it will garble on the screen and only one time has it garbled for a few seconds and then changed to good! Once in a while, it will boot normal.
If I put the strata bowler gameboard in it (which is what the cabinet was setup for) it will boot everytime.
If i put the 60-1 in any other cabinets, i have no problem with it. i have big buck hunter cab with a 25'' that works great that i may turn vertical, but i'm wondering why the other just won't work right. ideas? Low power supply volts?
Thanks, James
Most likely you just need to tweak the hold pots a bit when you swap that board into that cab...
