gobsgraham
Not sure if it is Gzero7 or G capital O 7 but that doesn't really matter.
I screwed up and need some help. I had a G07 here that had the yoke wire connector broken into 4. The monitor came out of a Monte Carlo and I rebuilt the chassis and plugged it back in and forgot which yoke wires went where. I plugged them in based on how they were formed rather than coming here in the first place to check and see how they should be connected. When I plugged it in R515 smoked because I had plugged flipped the Red and Grey wires (the two wires on the right when looking at the chassis. When it was smoke there was vertical collapse. Now when I plug the wires in properly, the whole image is blue and shrunken to around 3 inches by 6 inches. I will add a picture tomorrow.
Did I just smoke R515 or do you think that I did other damage at the same time?
Do you think I would have damaged the yoke? or anything else?
Has anyone else done this before? I found one or two threads with similar cases and R515 but no real closure on how to fix things.
Hopefully someone else has done this and can guide me to the quickest way to fix it and regardless of what happens I will make sure that I update the thread and so the next newbie that does this can hopefully fix theirs.
