Hey guys,
I have a dynamo cab that I want to get into to do some rewiring, but it doesn't seem to have a removable back. I can get the console board out ok, but there's so much empty space at the bottom, it would be perfect for a multi jamma setup, theres just no room for all the boards on the pull out drawer.
I suspect the back is pegged into place like ikea furnature. Looks to be sandwiched between the sides. Inside the cabinet, the tops of the sides are bolted into place and act as a load bearer for the monitor, so I'd rather not remove those if possible. Is there any easier way to remove or make a door on the back of this thing? What have you guys done on machines with no removable back?
