Help anyone have a cap kit list for a Nanao MS8-26A
rmackie6661
Cottage Grove, Minnesota
Help I am in need of a Cap kit list for a Nanao MS8-26A
I have all the caps but just want to make sure I have the right locations for them all.
You can just pull a cap, then replace it with the same size. Do one cap at a time. Mark the top of each old cap with a black dot so you won't miss one. Easy...
Yes I could do that but I was hoping someone had a chart so i can pull all the caps I need then dig in. I really hate doing it one by one. and I just wanted to compare the Uf and voltage to a chart.
Same VALUE .... ;)
(I knew what you meant, but others may mistake that)
uf must be the same, voltage can be higher but not lower.
Same SIZE does matter.
You can go smaller in physical size, but not bigger. Some caps don't fit based on items around the cap. An example would be caps that are snuggled up to the vertical output IC heatsink. Tall skinny caps work, but the shorter, fat ones won't.
You have to look at the sizes on the replacement caps to ensure you get what you need.
RJ
Yup really all I need is a Cap chart. I have done a ton of re-capping and have no issues with it But I just want to be sure after I take the caps out. SO really I am just looking for a chart. Anybody have one???
