help a Golden Tee noob
mungrin
New York
Just picked up my first Golden Tee cab.2005 fore! extra or that's what it says. I love GT but I don't know anything about this cab. I can't even figure how to open the control panel. There's gotta be latches I can access. Can someone point me in the right direction?I have the manual from IT but it has nothing on the cab itself in it and I've been searching a lot online. There is no bill acceptor either. Does only a specific model model fit in this machine or can others fit?
If you open the coin door and reach back in the middle, there is a latch that when unhooked will allow you to pull the control panel towards you and up kinda on an angle, and then there are 2 latches that you can get to after that to open the CP. Not sure about the bill acceptor, but I guarantee someone on here has one for a GT.
Yeah, what he said! To access the PCB you need to pull the control panel out and down to reveal the flat space it's living on. There should be a remote board for monitor adjustment there too. To adjust monitor color, flyback, etc. you do that from the back. Everything else, from the front. It's a cool cab, for sure.
There's a lock in the back I just noticed and I don't have the key. Guess I have to drill it.
Is the'Mars Mei AE2631-D5 bill acceptor the only one that will work with my machine?
No. Any DBV that will work in an arcade function (instead of a vending function) will work, although you may have to adapt the wiring to it...
