Having some multicade cp blanks made...
arcadeshop.com has multicade blanks made to Pac/Ms Pac dimensions for 48/1 or 60/1 layouts for $28 plus shipping.
Just thought you should know before going thru the effort locally.
Thanks, I have an old taito cab that they won't fit on, plus the guy basically has suggested I can get the same price with any quantity. Wish I had a Ms Pac/Galaga that I wanted to swap around....
I have a Qix Taito panel, which is perfect for Multicade, you can have for shipping. I started to strip the CPO a while back, but got sidetracked.
Either way you go, you will still have to make the wooden mounting brackets for the metal panel.
My problem has been cutting the hole for a trackball, aluminum is easy to cut, but the steel I've been looking at is not so easy...any suggestions? Is the Qix panel steel or aluminum? I already have the taito wood base from my Stratovox, but my CP was hacked up when someone drilled extra random, poorly placed holes....
