Having problems with older golden tee 99'
arcaderookie
Tennessee
Sorry I put this in the wrong place. I hope I got this right this time. And I am sorry for making the same post in another section. Didn't know how to move the post over. Again I am sorry for that.
Was Wondering if anybody could help me out on here. Why there are so many knowledgeable people on here. Don't know whats causing this, but was wondering if I can fix it.What I am having problems with is my golden tee 99'. Every time I turn it on the volume goes high and then levels out when title screen comes on. Maybe sooner and sometimes later. Is this a common for this to happen. If not, what can I do to fix this. Second problem I am having is when I go to shut off the game it just about always trips my breaker and makes this pop noise thru the speakers. I have did a self check on the pcb board to make sure everything is ok. I also put in other golden tee boards in and it does the same thing. checked voltages to the power supply and thats ok. Not really sure what else to check. If I could get some advice that would be great.
Thanks in advance
Sounds like there has to be an issue with the power supply or bad wiring in the cab. Do you have another PSyou can test it with?
I will buy a new power supply and check to make sure. anybody else have any other ideas on this..
And thanks Adamdiz will check when I get new ps.
thanks
anybody else got any other ideas..put new ps in and it is still doing it..I cant figure this out. could it be something bad on the board.
thanks
Bummer that didnt fix it, I dont have a clue, hopfully someone will.
BTW, it is NOT normal for the sound to do what yours is doing. Mine doesnt. But im not sure why yours is. Sorry :(
