NEW Having an issue with the lights on my Baby Pacman
Shawn1976
Donor 10 years: 2016-2025
Saint Augustine, Florida
I've already switched them for new ones, so I thought I'd throw that out there first.
Anyways, I'm having issues with a certain set of lights on my Baby Pacman playfield as well as the coin door lights.
The below listed photos shows the 9 lights I'm having trouble with.
I'm also not getting any lights from the two front coin door lights.
Any suggestions as to where to start?
These are steady / unswitched G.I. lamps, right?
If a break in the wiring isn't your issue, I'd trace it
back and see if you have a fried connector or a
supply issue. If the connector becomes unseated
or filthy, it will heat up and burn itself (same is
true for wiring and solder points).
Yes to the lamps.
Tracked both the coin door lights and the back playfield lights to the power supply at the bottom of the game.
Does anybody service this power supply?
i actually found a replacement set of parts on EBay to hopefully get my power module up and running.
Failed lights on Baby Pacman usually means a failed transistor on the lamp board. Check the manual and see which transistors affect the lamps you are having problems with
If your referring to the playfield lamps powered by the solenoid board, these lights I'm referring to are directly powered by the bottom power module.
Traced the wires directly from the lights and they go directly to the power module.
The lights don't even show up on the diagram.
There the 9 lights directly behind where the ball would go.
I was referring to your failed P light on the playfield, but I can see you have circled the lights at the back
