Haunted house lighting question
jeff412
Buna, Texas
I have a haunted house that the sequence light #1 on the lower playfield is on when the game starts up. I haven't played it long enough to see if it changes because of some other issues. Is this normal or do I have a flaky transistor somewhere?
Thanks,
Jeff
No it just comes on when I start a game. That is great news. I was afraid I had some other issue, because the transistor tested good. Thanks for the info.
Jeff
yep. Played a full game today and it does light up 2 and 3 as the bank is completed. What does that get you?
Jeff
More points! :p
According to the scoring and gameplay sheet I have:
"Completing the lower level target bank twice or the upper level target bank three times lights double scoring on the middle level."
...and...
"Completing the cellar (lower level) drop target bank twice lights the top left hole located on the middle playfield. The ball entering the hole lights double monus for the attic."
...and...
"Completing lower level target bank twice lights upper level bank for Special."
...and...
"Completing sequence twice lights attic (upper level) for Special. Left top hole on middle level and middle level for for double scoring."
IMHO, the rule-set for HH is an aweful convoluted mess. On top of that, Gottlieb's explanation is poorly written.
The sheets used to be online... can't find them now. Anyway, here they are.
Darren,
On your Haunted House, does the vertical upkicker from the lower playfield have a plastic tip on it or is it just bare metal?
Jeff
