Has anyone use q-bert with a vga converter?
Dr. Willy
California
I acquired a q-bert cocktail that was mussing it's 13" monitor. I have. 17" wells d9100 that in found will fit in the cabinet however the 9100 is vga input only.
I know q-bert is positive sync so I changed the 7407 at j14 to make the sync negitve then ran both of them together and wired them up to a gonbes 9200 vga converter. Hooked up th vga monitor and I have a picture but it won't lock reliable. It will jump around about every 15 sec in random directions.
Has anyone successfully used a vga converter with qbert weather it be in a cab or bench testing setup?
Sounds like a candidate for a jrok
I'm not quite sure what you mean. I didn't know anything about these jrok boards, but just googled them. And as far as I can see, they don't output VGA... and they all seem to expect comp sync at the input...
If the converter takes negative composite sync, you can not just run the 2 signals together without a gate. I had a I similar problem some years ago. Depending on if you combine signals before or after inversion, you should use either an AND or an OR gate...
Details on what I did is in these 2 FB-posts:
https://m.facebook.com/story.php?story_fbid=139106149593064&id=137999229703756
https://m.facebook.com/story.php?story_fbid=139276496242696&id=137999229703756
So seeing how I already changed the 7407 to a 7406 and the board is putting out negitive h and v sync sounds like I need an AND gate. I'm still learning my way through IC's can you pint me in the direction to one that will work?
