ronniep
First off that you for reading this. I have done a bit of searching and have not found a lot of the information I am looking for.
I currently have a working Hard Drivin' cockpit that is missing the magnet under the seat that locks it into position. If I remove the floor board I see that there is a connector right where the magnet should be and another coming out from under the abort button. I am looking to replace the magnet, but cannot verify that is all that is needed since there are two connectors connected to nothing.
I am looking for two things. The first would be a correct wiring diagram for a cockpit version. The second is the gauge of wire used in the magnet. I only ask for the gauge of wire because if I cannot locate a magnet I will just make one.
Thank you for your time!
