Hard Drivin Problems
oschonor
Ohio
No Voltage getting to seat magnet nor shifter magnet. Where and what to check? All fuses look good.........
............and it must be a later model cause it actually has a race drivin type shifter set up with a spring loaded solenoid, not the large magnet type.
check the apu pcb for cold solder, and actually pull each fise and check it with a meter.
On my hard drivin i had two fuxes that looked fine but were dropping about 50vac internally
ok, i got the seat lock magnet to work. It was a disconnected wire on top of power supply. I still cant figure out why there is no power to shifter solenoid.
Board solder points seem ok but still no voltage getting to shifter solenoid.
