animesuperj
It's a slightly modified japanese ps2, it's not the same one you would get off the shelf with the i/o on it.gamefixer said:The "motherboard" in question here is a Japanese PS2. I have another working DDR Super Nova CPU here that I'm going to pull the hard drive from and put it in the other machine to see what it does. I expect that its going to boot which would mean that they are NOT married.
If you just swap the drives from one python unit to another, it won't work; I know people that have tried.
The drives aren't specifically "married" to the python unit, otherwise you wouldn't be able to buy upgrade kits from SN1 to SN2. The reason you have to send back the entire motherboard and drive, is because there is some encryption between the two units. It's low level enough that you need to know certain commands and have specific access to sectors on the drive. You're not going to be able to crack it. Your best bet is to either ship the stuff back and have it repaired; or buy new hardware all together.
That protects konami from people pirating the game, which in this case is what is trying to be done. I understand that the game is just trying to be backed up, or transfer; but think about it. If you can do that as easily as we'd all like, what's to stop someone from just copying a drive and giving it to another person with python hardware? That's bad business for Konami, hence why you can't just "copy" a drive and stick it in some other unit.KevinMullins said:So in order to replace a bad HDD you have to buy the whole motherboard setup ?!?
That is insane.......
All it comes down to, is you're not going to be able to copy the drive. Like I said, I see two options. 1. Send it out and get it repaired. 2. Downgrade to a 573 unit and play 3rd-extreme; or else stick something else in that's new hardware.
