Happ potentiometer
tddlny
Plainfield, Indiana
looking for a good HAPP Steering Potentiometer. (need it for a Ridge Racer 2 but I know they used it in many different games) A lot of the NAMCO games used this pot. HAPP part number is 80-5026-00. It has the longer 1-1/8" shaft. let me know..... Thanks!
Ted
just a one turn pot? what value do you know?
if its a 5k rat shack has one ive been able to make fit into a lot of games simply by cutting or grinding the shaft as necessary.
http://www.radioshack.com/search/index.jsp?kwCatId=&kw=5k potentiometer&origkw=5k+potentiometer&sr=1
i found a ridge raver v manual and the namco number for that pot is 88800053 but of course, not much luck tracking that down either. THey do not specify a value.
steering is something on these that needs to be reinitilazed when your done and periodically, so i guess the dumb question is have you tried a reinitialization yet?
Thanks for the info. Switch sound slike gravel inside when you turn it and is very sloppy. I am sure it is junk, probably why I got the game so cheap. Should be an easy fix...
I found an old thread from Ken Layton that recommended these Honeywell pots as nearly universal replacements for general arcade steering/pedal use.
http://www.mouser.com:80/Search/ProductDetail.aspx?R=53C35Kvirtualkey67810000virtualkey785-53C35K
As with other generic replacements, these will require some Dremel or filing work to get them to fit. That said, these are far cheaper than factory replacements.
Edit: Found the thread. Credit where credit is due. :)
http://forums.arcade-museum.com/showthread.php?t=23561
