Happ guns on point blank 2
Choosterbuck
Toronto Ontario, ontario, Canada
Hey, I have the system 11 version of point blank 2 and was wondering how to go about hooking the guns up. I have happ guns rather than namco guns.
I have noticed that when I click button one on a standard jamma pcb it controls the trigger.
So, I have ground*,+5*,and trigger*.
I just need to figure out which one to hook up to the gun sensor.
Any Help Would Be Greatly Apricated
This includes the Happ gun pinouts: http://www.happcontrols.com/images/pdf/opticalgun.pdf
Look like Clay Cowgill was once trying to figure this out:
http://groups.google.com/group/rec....read/thread/5221b99373ac79ff/5ef48bbfad4e1fc7
NathanK later posted some details about the pinout of PB2:
http://groups.google.com/group/rec....read/thread/db58f315155077cf/098deee00dca1346
So, it looks like the gun sensors are on J3, but the triggers go through the JAMMA harness (as you found). Odd. No +5 on J3 either, so I guess you'll have to nab that from elsewhere too...
Hi;
I am piecing together a Point Blank 2 and I wanted to thank you for posting the Gun wiring information. I knew the Red/Black but was not sure of the White and Blue...... Harness has been modded and I will be hooking everything up in a bit....
Thanks again
Jeff
Yes, this is an old post... however... I am attempting to wire a POINT BLANK (not 2) to Happ Guns... is the above chart for PB2 accurate for PB as well?
We just did a conversion of a Point Blank 2 kit game to Happ guns and it was a little different from everything else that I've seen mentioned on the forums, so figured I'd follow up here.
The picture below is of a 15 pin amp mini plug from PB3 kit manual, but it is exactly the same for the guns on PB2. So, in effect, this would work for both.
The connector is a 15 pin stacked in 3 rows of 5 pins. It counts right to left 1-5 top row, 6-10 second row right to left, and 11-15 third row right to left.
The Happ guns are as follows:
Red - 5v
Black - ground
white - trigger
blue - sensor
So, for gun player 1, you tie the following:
Happ Red 5v -- pin 4 (red wire)
Happ Black ground -- pin 8 (black wire)
Happ white trigger -- pin 7 (blue wire)
Happ blue sensor -- pin 9 (white wire).
Gun Player 2, you tie the following:
Happ Red 5v -- pin 5 (pink wire)
Happ Black ground -- pin 13 (black wire)
Happ white trigger -- pin 12 (wire color is different than listed in the manual, so can't remember, but count the plug properly to 12)
Happ blue sensor -- pin 14 (wire color is different than listed in the manual, so can't remember, but count the plug properly to 14)
There will be two wires on each gun not used that you can just tie off, one is for the 24v and one for the gun lamp.
Go into test and calibrate your guns and you've successfully converted a PB2 or PB3 kit game with the filter board to Happ guns.
