So I have a working hantrax 9000 take it for an hour drive in the back of my truck, when I plug it in it works for a few seconds and I see it spark. I take the chasie out and look at it I find a burnt resistor I change it out fire it up and nothing happens except the degaus coil fires. I go over the flow chart and do most of the steps I couldn't for example change IC 2 because I don't have one but everything on the chart that I can check I have, I do have high voltage but disconnecting d10 does nothing, everything else on the chart appears fine. So I gave up on trying to trouble shoot because everyone including ken layton says on the hantrex start with a cap kit so I did a bob roberts cap kit, new fly new hot new filter cap and its the same, I don't think the new flyback has ever even had juice to it as I get no sound or spark or anything when I discharge it. The only thing I have found is there are 6 similar looking components on the board 3 of them show continuity and 3 don't ? even out of circuit so I would assume 3 are bad and they are near the burnt resistor. Can anyone tell me what they are and if they should are shouldn't have continuity when checking with the diode function on my digital meter? They are the green resistor looking things in the pictures.
