Hanterex MTC 9000 25" HOT retention clip.
PrairieDillo
Donor 2011, 2024
So I got around to pulling the monitor from my Operation Thunderbolt.
It was eating fuses from some testing from a friend so I pre-ordered a full kit from BR for it.
It's a keeper so I figured to do a full deluxe kit on the monitor.
On initial inspection it's an interesting monitor with a built on Fan for cooling. It had the HorWidCoil glued in place so hmmm how to adjust?
Well I noticed a crack and crystalized growth out of the side of the flyback so it's probably the culprit.
I was doing the HOT and as I put pressure on the spring loaded retainer clip, it snapped in 1/2. Does anyone know where to find replacements for stuff like that? I bent the pins on the HOT so it puts some pressure against it the film and the heat sink but dunno if it's enough.
I was missing a 2A fuse so I needed to pick that up today before i tested how I did on the monitor.
thanks
rentention clip replacement,
try a wire tie.
can be tricky however if you get it right it works great.
as in a zip tie? I was thinking of that but didn't know how hot it gets.
thanks Chad.
plugged the Hanterex in and the board smoked with a burn in the center of the board. DAMN!!!!!!
It may have to be sent to Chad now... even after a full deluxe kit....
