Hantarex polo Chassis, where do I begin?
keithsarcade
St Peters, Missouri
Doing another service call, this time trying to fix the dreaded polo. Chassis is on my bench and the game is a half hour away.
When removed from the game, it was getting neckglow at times, but no picture. When I removed the chassis, the connector for the degaussing coil came right off, and a solder joint for D135 was found bad. There are other solder joints I need to look at as well.
I'm clueless with this one, where do I even start? Are there typical culprits for this behavior?
Did you bring the tube back so you can bench test it? or do you have a tube for bench testing?
Do you have the polo flowchart?
