Timmy v boekel
Good evening everyone,
I need some help with a Hantarex Polo 25-inch monitor. I bought a spare monitor for my arcade. The problem with the chassis is vertical collapse. I replaced R167, which didn't look good and was very different.
When I turned the monitor on, the image was larger, I heard a whistling sound, and the monitor stopped.
When I measured the HOT it was shorted.
what did I do? I measured the diodes according to Randy From's diagram they are oke. I replaced C172, C174, and C175, and replaced the HOT transistor. I did the lamp test B+130 volts.
Then I turned the chassis back on, and it started ticking again.
Then I added another flyback that worked fine, with the same result ticking
At this point, I'm not sure where to look.
Any tips?
regards tim
Any tips?
regards tim
