Hantarex Polo 25 image shrink help
Good luck...
But in all serious check the control panel first see if the v size dial is broken if not it could be a handful of diodes or resistors, check to see if any are burnt out. There's a hanatrex polo repair service on eBay I recommend, I had the same issue with one about a year ago they fixed it
Good luck...
Checked V size and all looks good....not really excited to tear into this worm hole....any chance someone has a working chassis?
Hard to see from that angle but looks like there are black bars on the right and left?
If so, check horizontal phase if you get no movement check cold solder on pot / control board. Could be a horizontal deflection issue but I think sync wokld be affected too.
well
So interestingly enough, I have had this with two of my monitors that were hanterex when I pulled them from storage they were like that one. I haven't found the problem. Just sharing.
I have yet to actually look at the chasis, but I suspect the problem is going to be a ic. Or maybe a capacitor is the horizontal circuit, also for giggles id check the width coil.
I tracked this down on mine.
It has to do with the weight of the flyback. You can try to track down broken traces or cold solder on this one all day (I did, trust me) and even after resoldering everything and having continuity it would keep happening (I suspect just enough flex to strain a component or trace. Somewhere down the line it seems to be kicking the horizontal amp pot out of circuit which is giving it that half collapse and making it non adjustable.
This might just be an aftermarket fly thing, but if it is original you can give this a go too.
On mine, the weight of the flyback tipped it too far towards the back so it flexed the board a bit. This is even with soldering in the rear anchor. If you push slightly on the flyback to get it to flex (I am talking millimeters here) towards the tube, it should correct the problem.
The stock fly should be screwed into the frame so it shouldn't tip at all, if you have a stock fly screwed in and its doing this, loosen the screw a little and give it a little push and see if it fixes it. If it does, remove the screw and put a small nylon washer (or two between the fly and the frame. Screw it back in. Should sit snug.
To fix this on the aftermarket fly, I used a plastic PCB standoff and screwed it in which put just enough pressure to get it to sit snug and not flex anymore. Pic below. Make sure you put it on this side of the fly because when you screw it in it will push against and not pull out.
Good luck and keep those Polos going.
