Hantarex MTC900 in a Missile Command?
tb lilley
UK, United Kingdom
Hi, monitors really aren't my thing, so any help/advice greatly appreciated.
I have a Missile Command upright that currently has a GO7 in it. Nothing wrong with it, apart from terrible screen burn from what I think might be Pole Position. I also have, sat currently doing nothing, a Hantarex MTC900 with great picture, vibrant colours, and no screen burn.
Is it possible to use the Hanty? First obvious problem, I think, is that the GO7 currently gets 115VAC from the Iso transformer, whereas I think the Hanty needs 120VAC.
What are my options? Thanks.
If it helps, the Hanty manual tells me it wants 128VAC (+10% -20% 50/60Hz). Does that mean that the monitor will run off an isolated transformer that kicks out anything that is up to 10% more than 128VAC, and anything that is 20% less than 128VAC? The transformer in the MC only gives out 115VAC.
