8BitMonk Member Donor 2015 VAPS Joined Oct 24, 2014 Messages 282 Reaction score 6 Location Eagan, Minnesota May 9, 2017 #1 Need a cap kit for a MTC900/E and not sure if it's a DE-1 or DE-3 version. What's the easiest way to tell? Pics below if it helps. Thanks!
security0001 Well-known member Donor 6 years: 2020-2025 Joined Jan 10, 2011 Messages 9,349 Reaction score 2,811 Location Montana May 9, 2017 #2 i will shoot you an email on it. (for others its the pcb ID numbers since there is many versions of these boards on this chassis)
Ohmerone Well-known member Joined Oct 3, 2009 Messages 3,364 Reaction score 296 Location North Miami, Florida May 11, 2017 #3 You should look at the manual it has a lot of information depending if USA or Europe chassis. in klov under manual an compare the parts in your chassis. You need a belt clip on the vertical ic to hold it to the heat sink or another way to hold it close to the HS. You need to check for shorts before ordering any parts. Good Luck!
