I've got a 25" Hantarex 9110 that I can't seem to get adjusted correctly. The geometry looks good (or at any rate close enough for me
), and none of the colors appears to be abnormally dark compared to the others. I did a cap kit, but I can't get the picture bright enough without either turning the screen up so high I get scan lines or the individual color controls up so high they start to bleed everywhere. The tube has some burn, so I was hoping to go with smoked glass/plexi, but there's no way that will happen with these brightness levels. I've got Area 51 in the cab, and the light guns need it to be relatively bright. They work now, but the picture is either way too dim or the colors are bleeding over everywhere making it really hard to see.
I have not yet changed the flyback, but am I correct in thinking that this should be the next step before a rejuvenation? The only problem with replacing the flyback is that the replacements for Hantarex monitors seem to be problematic from what I've read. As far as I can tell, none of the flybacks sold by the regular places will physically fit without me cutting the metal frame (which I can do, but I'd rather not have to), and they are of sketchy quality. Does anyone have a line on a good replacement flyback for a Hantarex 9000/9110? Or should I just skip replacing the flyback and find someone local with equipment for a rejuvenation?
