Hantarex 33" cap values
salmart
Spring Valley, California
Anyone knows the value of these two capacitors?
According to cap kit C144 should be 1000mf 35v (right now is 2200mf 35v) and C181 should be 4.7mf 450v (right now is 10mf 250v)
This is a 33" hantarex monitor I'm working on. Right now its in shut down mode.
those caps are correct in the kit for the 25inch and smaller but i don't think they are for the 28 and 33 so i would put in the same caps that you took out and don't use the caps in the kit for those locations.
was that the only difference is those two caps on the whole monitor??
You got a picture of the chassis?
so all parts can be seen.
Sometimes a visual inspection by an experience person
may see the problem right away.
what game its used on.
I would expect more then e-caps or the ones you mention
to complete this repair anyway!
