Hantarex 25" pot knobs missing
videodan
Donor 3 years: 2023-2025
Melrose, Massachusetts
I picked up a 25" Hantarex yesterday, and noticed 3 pot knobs were missing. I looked down at the back of the chassis, and found the 2 tall colored knobs, but the knobs for the other 3 were not there! I'm under the impression they are for V-Hold, H-Hold and another adjustment (which I can't think of right now).
My question is: are there replacement knobs out there, or would I be able to toggle these with a certain instrument? I powered the monitor up in my multi cab, but all I got was a multi-colored line going across the screen.
Please advise. Thanks!
If these were from the pots on the remote adjustment board, they fall off all the time. Depending on the particular pots that are installed on the remote board, you can either use an Allen wrench, plastic alignment tool, or a small straight slot screwdriver to turn them.
No, these are all on the neckboard, not a remote. There are only 3 empty holes, which gadget would be best to put into these holes for adjustment?
uh, you can rob one of the knobs off the remote, they're all the same size.
and if you have none of those? I don't know what to tell you. get your jeweler screwdrivers out.
