Anybody buy this game?
If you did, does the pistol have its scope and explosive bullets?
The M6D is a semi-automatic, recoil-operated, magazine-fed, large-bore handgun that is controllable even during rapid fire, although at the cost of accuracy. In-game, the player can hold the trigger down, and the weapon will fire repeatedly without additional pulls of the trigger. It is most likely striker-fired, due to there being no visible external hammer. It fires M225 SAP-HE (Semi-Armor Piercing, High Explosive) rounds from a 12-round magazine. Operators can achieve an effective rate of fire of 3.5 rounds/sec or 210 rounds/min. The weapon is very accurate out to its maximum effective range. This accuracy allows incredibly precise target engagement at long range.
The M6D uses 12.7x40mm M225 SAPHE (Semi Armor Piercing High Explosive) magnum loads. These rounds have a jacket of copper or cupro-nickel around the projectile while the projectile itself is hollow and filled with an explosive compound and a delayed-detonation impact fuse. When the round impacts a target, the jacket will initially help the projectile maintain its shape, allowing it to travel into the target before detonating almost immediately after impact, causing massive tissue damage and system shock.
So you never played Halo? Not a great video, but at 20 seconds you can see the player using the scope. And yes it uses explosive bullets.
OF Halo I,II, III....
Only the first one had a decent (and challenging) campaign.
It does have its own online play, but that's limited to 7 maps. The game includes a DL code so you can DL those same 7 maps to play on Reach as well. This was intended to prevent friends from just sharing one Halo CEA disc to copy the maps over to Reach and play. The game shares the same servers as Reach but Reach players can choose if they want to play the CEA list.
Wait wait... are you telling me that Halo CE Anniversary has online play - but its REAL Halo? Not Reach, or Halo 2/3/ODST online - but it's as if I've connected several original Xboxen together?
Even if it's only on 7 maps, I don't give a shit. I'll plug in my 360's CAT5 cable tomorrow!
Please clarify!
