Fusion916
Had montior chasis repaired, hooked it up, monitor DOES NOT WORK
Monitor: Nanao MS9-29
Symptoms before I sent the chasis in for repair:
When I turned on the cab, the monitor sounded like it was powering up for a second, then shut off. You know the brief "static" sound that builds up in a crt before the picture turns on? Thats the sound I heard briefly before it turned off. No picture the whole time.
So I sent my chasis in for repair, they fixed it, said it was working fine before they shipped it back. Recieved it today and it was wrapped very good so there is no reason to thing anything broke in transist.
I hook up the chasis, turned on the cab, and this time the monitor turned on and stayed on (the static sound built up, did not hear the monitor click off), but I still get absolutely no picture. Not even a fuzzy/gray/white screen, just a totally black as if the monitor was off. When I turn off the cab, I hear the "click" sound of the monitor turning off, so I know the monitor IS on the whole time. I tried adjusting the control panel pots, no effect.
I really need some guidence here as I definately see a "fix" in the monitor chasis (monitor stays on the hole time), so the repair did something and they claimed the chasis worked for them, but I still get no picture on my end. Where can I start debuging this?
Here are some pics from the chasis, maybe I hooked up something wrong?
As you can see in the last pic, there is a missing header there but I don't see anything to hook it up too and I don't remember if anything was there when I first removed the chasis.
Also, I'm not 100% sure I properly attached the anode if that matters. It "feels" like its in there tight, but I'm not sure I properly connected the metal part. What are the prongs suppose to be touching?
