Gyruss - no video. need help and direction
otoko
Big Rock, Illinois
I have a Gyruss machine that was working perfectly fine up until two weeks ago. Whenever i turn it on I hear it make game play sounds and the game is playable, but the monitor does not turn on or show life.
Background information:
This system had sat for a month before this problem occurred and it ran perfectly
The system turned on and the monitor flickered as if turning on and then nothing
It has an updated new power supply but I do not think it is faulty... yet
where should I start figuring this out?
I guess it depends on what you mean as you have already "figured out" that your monitor is dead. The power supply only feeds power to the game board and since the game plays blind, your board and power supply are both almost certainly fine. Monitors will die at anytime for any reason regardless of whether or not it was working perfectly an hour ago...
The question you need to answer for us first is: Do you want to fix it yourself or are you just looking for a replacement monitor?
Double check all the monitor connections. What kind of monitor is it? If it's a G07 the fly probably went. Check F901 and F902.
