@mecha (I have seen your posts about games like Gyruss needing extra power to the boards, so I figured I would list you in this post)
When I start my Gyruss "cold", it boots to garbage (actually a screen full of upside down "A" characters). Eventually, it will work its way out of that and play fine. It takes about 2-5 minutes.
I could tell that the voltage was low at spots on the board. So I ran another set of wires to the lower board from my power supply (as @mecha has mentioned in the past). I figured that would fix it. Unfortunately I am still having issues. It still seems to take awhile to "warm up" the boards.
I have the voltage such that I get 5.10 volts at the supply, 5.07 volts at the header on the top board (I cleaned it), 5.05 volts at a ROM on the top board, and 5.05 volts at a ROM on the bottom board right out of the gate and it still does not get going. It eventually settles at 5.22V, 5.18V, 5.14V, and 5.14V respectively. If I turn the game off and then turn it back on, it works instantly. If I wait 10 minutes or so, the process starts again. I am not sure that these values are super important at this point since I can turn my supply up, get higher voltages all around the board, it is still does not boot right away.
I also recapped the major caps on the board initially thinking this might be the issue but I saw posts about directly hooking up the lower board and figured that had to be my problem.
Anyway, I am guessing it is some component issue at this point but would be open to ideas. The game plays fine but it bothers me that this does not work and I worry it is indicative of another more serious failure to come.
