Whats the correct way to tie left and right channels together on a gyruss jamma adapter to play the game in a mono jamma cab? Will this result in impedance problems for the amps/speaker?
There is a jumper on the pcb that will pump all sounds out one channel. Its located right behind one of the amps. Simply jump the two posts and you have mono.
I do this when running them on the bench. If I were to install in a cab I would add a second speaker. After all, the sounds are what makes gyruss such a great game.
