gyruss help
pinkfloyd
lowell, Massachusetts
hey,need some help,my gyruss arcade game is stuck on the main screen,and some scrambled on the screen?i was told it was the power supply i installed a new one still the same problem?hope some one can help thanks
Post a pic if you can.
First step should be to check voltages on the board. If you're getting all the required voltages, then you can move to checking for other things.
If your +5 is low/high then you can start tracking down where the problem is. It could be the Power Supply, the Harness or something on the board itself. Since you replaced the Power Supply already, chances are, the issue isn't there.
If you don't have the manual or schematics for the game, you should be able to find them on: http://arcarc.xmission.com
